OEM Grip heaters backordered
FriscoProx
Torn the wiring from one of my grip heaters. The OEM's are on backorder. What's a good aftermarket alternative. And can one OEM and one after market heater be used. Thinking i'd only replace the one unless I had to change both. And any trick to getting grips back on without destroying the heater element?
They are separate plugs on each side, down by the steering post. Any aftermarket heating element should work fine. keep the stock one handy incase you need to cut the plug off for the new element.
Air compressor for the removal, and install... or a little spray paint for lube, & twist that sucker own Fast
Also the PRO RMK heater grips will also work. They have the same plug in but the wires are a bit shorter. They will still reach the plug in if you have stock height bars.
And to remove the grips easily is use a blower tip nozzle on your air compressor and blow the grip off. Same for applying. Works great!
Handwarmers
How many handwarmers do you need? We have several of them in stock, and could them shipped out to you today if needed.
