bcsnowdog Active member Lifetime Membership Mar 22, 2009 #1 primary bolt has come loose twice on 06 rev 800 was tightened to 80 lbs?any ideas?
P pauly-doo Member Lifetime Membership Mar 22, 2009 #2 clutch bolt had that happen to a 670 motor,needed a crank and bearings.it also broke a few clutches...hopefully it is something simpler then that..
R Red-eye Well-known member Mar 22, 2009 #3 bcsnowdog said: primary bolt has come loose twice on 06 rev 800 was tightened to 80 lbs?any ideas? Click to expand... Did you run it and retorque ? Change bolt ?
bcsnowdog Active member Lifetime Membership Mar 22, 2009 #4 the clutch bolt came loose on it's own after 6000 kms.
S snow_freak ACCOUNT CLOSED Mar 23, 2009 #5 6000! well no $hit, you should have to atleast clean the dam thing with that much.
C Crasher Free Member Mar 23, 2009 #7 Make sure you put the washer on the correct direction. I have seen it installed backward before. They have a slight dome in the washer. The cupped side faces the clutch, and the dome faces the bolt.
