Moto-PsychO,
Thanks for the link, but I was hoping to eliminate the stock kill switch completely. The link is for wiring in-line and retaining the stock kill switch.
modsledr
Did you ever figure this out? I did it tonight, TORS gone, tether working and no kill switch.
Remove the plastic with gage and main ignition switch (thingy with key in it
Main harness connections (lower right)
The upper steering shaft mount has a bunch of wire looms there. Take the corrugated tubing off the wires that go to the handlebars. There are a couple of looms there in plastic, pick the one that has 4 or so wires in it and feels more defined when pinched. The other one that looks similar has only 2 wires , each in its own sheathing so it doesn't feel the same.
sheathing cut open
Cut the sheathing open. The Brown and Brown/White wires from the sled to the handlebars go to the kill switch. Cut the wires and attach you tether to the side coming from the sled. Note that I used a normally closed tether from arctic cat.
If you want to keep the kill switch, just cut one of the brown wires and splice the tether in there to both sides. This will allow either the kill or the tether to open the circuit and shut the sled down.
FYI - Note that there is also the Black/Blue and Black/Yellow wires. These are for the TORS system. Black/Yellow comes from the computer, Black/Blue goes to ground when the throttle completes the circuit.
Tether Connected (normally closed tether)
Finished
To defeat the TORS, you need to change the configuration at the main junction for the wires. All you do is take the white single connector from the sled and connect it to the black single connector to the sled. They should fit without any cutting or anything. Thanks to TY for this one.
Wires to reconnect
So you just connect the bottom two single wires together (one black connector, one white connector). I taped up the top two as a reminder that it is not stock.
Hope this helps someone.
