Bar Bag Option.
Chewy22
I tried the double bag I have on my 19. The riser seemed a bit short and thought it would hit the tether. I did not want a taller riser so was going to give up a bar bag. But then I was looking around in the accessory catalog and found the single bag version AC has for the Blast sleds. Works great and it’s the same size as the front bag on the 19.
Good find… surprised they did not advertise it for Catalyst models with 3.5” riser. I can verify from experience the standard bag will knock the tether off at the most unwanted times lol.
Thanks! ordered.
I ran my throttle cable threw the right side (throttle side) threw and out the front of the riser. It does not affect the cable at all for me and is protected from being grabbed by a branch.
Pay attention to the hood pinching it underneath also, for those that don't know.
Not sure if that'll work for you, just passing it along, gives it a cleaner look also.
I should of went with your style hand guards, went with the fancy pricey rigid ones and both failed miserably. One was taken off on a spruce branch the other snapped from rolling it over even though it was still pointed up hill and in powder.
I’ve been using the Polaris goggle handle bar bag, but put it in front of the bars like the blast bag.
There is an alternative to those who want to reuse their double bag or who have already ordered it. The rear bag will interfere with your tether. Simply use the front bag with the "Cat logo" on it, use the loops on the ends and use zip-ties to attach to your bars and riser. Still looks clean. I store my folding saw and pull strap in there.
