Nytro pump gas turbo ready to rock!
RACINSTATION
Nytro Meth Kits (PUMP GAS TURBOS) Ready to Rock!
We have been doing some testing and r&d on the Nytro turbo for the past few months and have an exciting new development.
First, for all turbo kits. We can run with a head shim up to 18-20 lbs of boost with meth.
For stock compression 15 lbs with meth and 87 octane fuel.
We have been testing various turbos and superchargers with awesome results!
PM me if you have questions. We have been working with Hurricane Performance in Canada......I don't want anyone to think I am hijacking Dave's work because he has been AWESOME to work with.
These kits will work with all turbos and supercharger. They come complete with our instructions and tuning parameters.
I think you mean Nytro Meth Injection kit for turbos right? or are you talking whole kit?
If meth kit, am interested in cost for mainly security for mine...
Sorry, changed the title for a more appropriate one. The kits are $599 USD and include custom tank and clear instructions for wiring into the Nytro harness as well as specific instructions for your brand of turbo etc. They are using right around 3 quarts of Meth/Water for 8 gals of gas. You can run 85 octane up to 10lbs of boost. 87 Octane up to 12 lbs of boost. and 91 Octane for 14-18 lbs.
We have found that you need bigger injectors for much over 12lbs of boost.
15 pounds of boost or less we have found no head shim to be fine. 15-18 lbs you need a head shim and 18+ you need rods.
What exactly is water\meth? Where can you get it? is it expensive? Are their any negative effects on the longevity of the motor? Thanks Dave:D
I've been reading around on this for a while, and think it'll work just great. Only thing I'm wondering, is how much will the stock rods in the Nytro take?
Wonder no more! The stock rods are good to 19LBS of boost. 20+ you need better rods and low comp pistons.
Water/Meth is available at Wal-Mart.......:) It is just -50 windshield wiper fluid mixed 50/50 with distilled water.
18lbs of boost on 91? This does not sound good to me. How many miles do you have? What kit is it. What this kit will do is save your head and valves.
drink: Are you running a head shim? Are you running stock injectors?
Let me know. Still intrigued on this setup.
I am already running 18 lbs on 91. What will this kit do for me? Is it beneficial?
Sounds like the perfect recipe for detonation.
Meth injection like race fuel helps to prevent the dreaded detonation problem.
Read numerous mixed reviews on meth injection, mostly related to moisture they generate. Most have been happy with the protection it provides and not having to be hassled with race fuel but the big question is what other future problems will meth lead too.
clean install RS.
Yes, I have a head shim, stock injectors. I was really hesitent to try this but mark set it up and he told me there would be no problems. So far none!! That is where mcx tells u to run it at with the upgrade. So thats where its at.
Will the meth inj. give more power and cool things down or just cool things down. I am interested. Where does it inject at? How much fluid does the canister hold?
drink..... i think in your case the benefit with meth injection would be to go "no shim" for better response and still no race fuel.... if you think you need it :eek:
