So is this a continous loop I am wiring into? I am not getting heat out of the new hand grips even though I have them supposally wired correctly? Any more info on the Wiring on the GT?
How do you wire the three RSIwires to a two wire system apex gt? I know that the rsi wiring is white is hi, blue is lo, and red is ground. On apex gt left bar is yellow and black, and right bar is black and black with red strip? Do you wire hi and low toughter? as positive and red to ground or is it more complicated?
yes, hi/low twist together and solder to your 'hot' lead from the sled.
ground from heater to ground lead from the sled.
Thanks for collecting this info Ruffy.
You know your torsion spring is not in the plastic block right? Nice looking ride BTW.
I'm going to order the RSI backcrounty bars, stubby hooks, heater elements, and 8" grips. It'll be nice to have warm hands this season.
Are you guys using aftermarket bars running the stock plastic block(with the handwarmer controls) or running toggle switches? It would be nice to get a toggle switch, AC wilwood brake reservior and ditch the entire yamaha brake/heater block.
Good call, no did not even notice. I have an M-10 on the way so hopefully wont have to deal with this stock suspension much longer. The scary thing is I went riding last weekend and did not even notice!
South Seattle is one of the cheapest dealers to order OEM parts, easy online ordering.![]()
