I have a set of the grips coming my way, and I also have got the information on the RSI extended grip warmers. The grips have two elements per warmer, a high and a low. Below are the specs.
High = 6.4 ohms rated at 30 W
Low = 12.8 ohms rated at 15 W
The two elements can be wired in parallel for one side. That will give you the following
One side in parallel (high and low) = 4.27 ohms
Both sides in parallel again = 2.135 ohms
P = V^2/R so power of the handwarmers = 79.16 Watts
This assumes a voltage of around 13 volts. It looks like these will be a good match for our system.
I am going to be getting my hands on an oscilloscope soon (Mon or Tues). I plan on verifying if indeed the warmers only work above 4500, what the frequency/time period is, what the voltage is and if it changes with setting, and what the pwm signal looks like for each setting.
I will also be checking to see what the resistance is on the stock grips when cold, and when hot. I have talked with some who think there might be a difference. We shall see.
Should be some interesting information, and will help to see what the limits of the ecu are, or at least define them a little better.
nytro stock
left - 7.3 ohms
right - 7.2 ohms
parallel - 3.62 ohms
total = 54W @ 14V
27 W ea grip
amps = 3.86
RSI grips - parallel high and low in each grip, then parallel between grips
left - 4.28 ohms (equivalent)
right - 4.28 ohms (equivalent)
parallel - 2.14 ohms
total = 92W @ 14V (used for comparisons)
45 W each grip
amps = 6.57 amps
hotgrips - parallel
left - 3.0 ohms
right - 3.0 ohms
parallel - 1.5 ohms
total = 130W @ 14V
65W ea grip
amps = 9.29
nytro w/ 06 apex bars
left - 2.2 ohms
right 2.2 ohms
parallel - 1.1 ohms
total = 178W @14V
89W ea grip
amps = 12.71 YIKES!!!!
In comparing the above data, it looks like the RSI's are a good match for the needs of the nytro.
One thing that has me curious though, is if there are guys running the 06 bars on newer sleds, even though they are only running on 1 or 2, if the pwm output is at full voltage, then they will be seeing full current. If this is true (voltage magnitude doesn't change, only pwm signal) then I would assume that the ecu can handle 12 amps or so... Maybe.... we shall see.
If anyone has an apex in the washington area, I would be curious to see if the pwm signal is the same...
