Nytro/MCX/Shockwave helix??
Klutch
Running my Nytro with head shim, pump gas and 12-15psi boost. I plan on changing to a shockwave helix and lighter weights for hopefully quicker spool up. Here's what I've been running: 66grm daltons loaded up to 75 grms and a p/s/p spring, secondary has a 45 helix with pink spring set a 1+9. I was thinking of drilling out the daltons and running the 66grm weight and running a white secondary spring set at 1+9 and thinking that would put me around a 47-48 helix. What do you think?? What about a different primary spring? Any help appriated.
Similar set up trying to remember what I have in it.
Primary 64g Daltons with B-W-B
Secondary Purple spring with shockwave (cant remember what its set at).
215lbs riding @4-6000ft
Havent had the chance to compare to any other similar sled/set up so no idea in how it compares.
I'm running with white secondary spring, shockwave set at 90 degrees preload, 15mm rolls and home welded weights. Was running MCX weights 88.5 gram, way to hevy.. running 17-18psi
16 psi, shockwave, purple secondary, 8bu weights with the large pins installed. im 170pounds running a 174. i was one of the fastest nytros at bis and im sure the only one on 16psi!
Triple black, are you running the epi purple?? or Cat?? Or are they the same thing?? What setting?? Thanks.
