P
any one else have any ideas for this without ripping off the grips and replacing the elements? i did the foam inside the handlebars and its still not enough. the yamaheater sounds great but over $200 is a little steep.
I finally figured out why the factory hand grips on the Nytro fail. The spongy material under the heating elements moves around allowing the elements to flex and finally break. When they are installed it's very difficult to wrap the element super tight to the handle bar, if you have a crease in the element wrap while you wrap it there is now a spot for the element to flex and eventually break giving you an open circuit.
best and simplest fix for the handwarmers...spray foam...is incredible the difference...try it...am sure it will improve them for you like mine did...
