Nytro Engine Temperature ?
G
GRINreeper
will the Nytro's stock gauge system give you a reading on engine temperature? I know it has a temperature warning, but I am curious to see what mine actually running at with a radiator delete.
If no reading, is anyone running a gauge ? and what gauge?
Normal operating temp is 155-185 or so. The fan kicks on at between 156-165 degress I believe once the thermostat opens. The gauge does not give a reading. Order the digital temp display from Ulmer Racing. Works great. Plumb the sensor in then tap to your ignition power so it comes on when you start the sled then ground it out. Reak easy and small. It also displays time.
Its the first item under accessories.http://ulmerracing.com/
Nuffsaid :thumb:
Thanks Very Much
