Nytro Bar Riser/Relocation....wiring/cable extensions?
Sunridge Sledhead
Who has cable and wiring extensions for a Nytro? I'm also interested in a steering column relocation kit? I hate how my bars come straight back at me, and they are way too low. I find I can only fit a 2" riser, or 3" tilted forward, with the stock cables and wiring.
(Maybe there are already threads on here, but I'm too lazy to search!;))
I found after wildchilds relocation kit that the ergos of the bars seem to fit alot better (I am 6"1). Need to spend some more seat time before I decide to go taller.
+1 for the wildchild kit. kurt makes great stuff. just ordered my second kit, putting one on the wife's sled now. ski
WildChild and powermadd pivot puts them in a pretty natural position...that position looks most like this...
once you get the bars moved, and up, you will love it...we are abotu same height, you should not have to extend cables at all...do the powermadd pivot, and then the wildchild reloation thing, and you will be groovin!!!
In case you dont want to do the relocate...I have the powemadd pivot and Fly 6" risers. The only extension I needed was the throttle cable, which CR Racing sells. Everything else has plenty of slack (I messed with the routing of the wiring and brake hose a little).
I have 8"risers that were made for my mountain max, when I bought the nytro they fit right on. They are cut at an angle on the bottom therefore moving them forward. They work great and look good. I didnt have to change any lines just moved my park brake line top other side of airbox shroud. I paid ~70us The name is oles machine his e-mail is mike@olesmachine.com.
good luck
yep. 'relocate' and pmadd pivot. i cut my stock riser down to fit the cables.
no more 'leanin over to reach the bars' for me!
~6' 2"
http://www.snowest.com/forum/attachment.php?attachmentid=56089&d=1234993075
Kimmy asked the question and ran...he must be trying to get his sled unstuck from teh driveway again!!!
:P
I did my own rider forward mod (similar to the rev 440's), and have the pivot adapter and a 6" riser. No problems at all with stock cables. I did do some re-routing though, and they all go behind the handlebar, not in front of it.
