Hi everyone!
I have been a member here for a year of so, done a lot of great reading, specially in the 900-section. My dad own a fusion 900 since 2006, i really like the torque and power in the bigblock polaris, so a coupple years a go i brought my own 900, only a rmk instead of a fusion. Got a cheap damaged 151" 900 with 230miles on it.
Modifications
Engine
- Ported engine, crankcase,cylinders and pistons /Compression 9.2bar
- Slp exsahaust
- Modded stock airbox
- probbaly more I can't figure right now
- New bearing and balanced crank
Drivetrain
- P-85 primary from a 600 "lightweight", black/pink sping, 74mtx weight maxed out(2steelrivets)
- stock team secondary
- 153" 2.25" track, 3.0" pitch 8 tooth drivers
- 19-39 gearing
Chassi
- removed front radiator and the cooler in front of the track, applied a larger rearcooler .
- Skinz airframe runningboard
- BOSS highrise seat for RAW
- Compfusion eniginemounts
- 09 plastic
- Homemade tunnel and cooler
Other
- Koso dual egt and air/fuel
- Boondocker controller
- rox adjustable riser and fly handlebar
Suspension
- a arms from a 08 dragon rmk, stock spindels with floats w/ swaybar
- Stock skid
I could need some help for a better clutch setup, normally i run from 1000 to 3000' . After the assembly I only run the sled for 8 hours or something, try to break it proparly. Ritch fuel and oilsetting, but still i god a fairly high rmp, the max readings at the MFD was 8100rpm. I'm pretty sure the HP will increse significant when i run it leaner. Some advice? Heavier weights and probbarly a steeper hellix right?
I have been thinking to increase the ski distance to 43" and swap the floats with a firmer shocks, how mutch do it matter? here where I'm driving it quite difficult terrain, could need more stability. What do you guys think about this?
There are also some parts I'm looking for, so if anyone knows of any for sale at a reasonable price is to contact me on PM.
WTB: Fire&ice airbox, y pipe slp, spindels from 08 or newer,harder springs for the skid, 8 or 9" inch wheels and freedom axle,thumbwarmer.
Ole Andre, Norway
Modifications
Engine
- Slp exsahaust
Drivetrain
- 19-39 gearing
Chassi
- 09 plastic
Other
Suspension
- Stock skid
Ole Andre, Norway
