Do you test the coils on 200 ohm or 2000 ohm. I'm guessing that .5 at 200 ohm means the stator is bad.
mine measures .5 with leads measuring .3 and that is on both mine and my brothers 900's
I've got 2 stators and both test good. The CPS test at 188 on the stator that is installed, my yellows are in spec, my coil wires are in spec, and my injector wires are in spec.
I've gone over all wires in front of the gas tank. Disconnected the handlebars, the tether.
I got a new flywheel, and when comparing the flywheel that I removed the outer ring was quite a bit different.
I damaged the original flywheel ring the first time I removed it by using a gear puller clamped to the outer ring. I straightened the ring but It must have spun while running in the engine. My belief is that this fried the ecu.
I have an ECU that will be delivered Monday, I'm hoping this is the end of it.
