2010 m8 no spark. Replaced wiring harness and stator. Unplugged handle bar controls, grounds. Only left is coils, can't be 4 coils or the magneto. Any ideas boys?
Have you looked at the wires going into the coils? I had problems with a few that had gotten between the gas tank and tunnel that had worn thru pretty bad and had one wire that had pulled loose from the back of the red harness on one of coils. I loosened the tank up a bit and pulled all that out from under the there. Not sure if that helps.
Bru
