No spark on 06 800
Hello Fellow sled shreds,
I am having a problem tracking down starting issues with my 2006 800 rev.
Sled would run and start fine when cold, but the oil light came on above 5k rpm... stopped sled checked oil, full... then the sled would not fire, no spark...
I fiddled around with all the electrical connections and replaced the relay, still dead. After about an hour the sled fired up, however I lost tack and insturment lights. Made a bee line for the truck, now I have no spark at all.
Any thoughts?
A friend and I pulled the coil and did a bench test. That seems to be fine.
Could it be the stator? If so, is there any way to test with out running?
Maybe the Voltage Reg.?
I am not much of a wrench, and electrical always seems to befuddle me.
Thanks
Try this. Un hook your kill switch at the plugin at the bottom of your handle bar. Then try to start it. I replaced my stator and it was the kill switch all the time. It would start and then wouldnt start like yours does.
