Stock 2014 RMK Assault
Sled will not go into reverse. When the push button switch is engaged the engine will start to die, like it's supposed to, but then rev up back to normal idle. I have tried a new switch, both the new and original ohm'd out just fine. I also have a service manual so I was able to reference the electrical diagram and get an ohm reading from the switch connection under the hood to the ECU connection, and switch connection to ground, both check out fine.
I'm not an electrical guru so any help, tips, or tricks, are appreciated.
