No gauges, speedo nada
D
DVarmit
ACCOUNT CLOSED
My buddy just bought a used 05 MXZ 800 and we took her for a spin today. I am a cat guy so I know nothing about the doo's but figured you guys could help. He fired her up and a beeper went off which I suppose was to tell him the oil was low since it was. Shut the sled down, filled her up and fired it back up now the gauges are dead. Now, I know the oil low had nothing do did with this but I was thinking that there was or might be a fuse or something that got blown? The gauges were working fine then bam no flickering on and off nada.. Just gone.. Any idea's? We didn't look for a loose connection which it could be but thought I would ask here before we set out on our search. Thanks
no battery model's have two fuses, there are in line in the wiring harness, open the pto side panal, look up twords the dash area. check those. also make sure the guages themselves are plugged in all the way.
Thanks, I will take a look tomorrow and let you know how I make out. Appreciate the suggestion..
I will say this sled is fast, pulls hard and takes the bumps extremely well. Almost makes me want to change sides. :D
Electrical
Also can check the lines under the fuel tank and to the rear light as they have been know to short out and give the similiar problems
Found the problem. Apparently one of the fuses on the left side under the dash worked loose and disappeared.. problem solved.. That was way to simple.
