nitro weight
I have done mine with about as much light weight stuff as possible without titanium chassis and mine came in at about 595 pounds wet. It cost a lot for what you get, my opinion go with power and good suspensions do the major stuff track,and tunnel.
I have 75 lbs taken off mine with stock tunnel and and stock seat.
ti a arms -9.5 lbs $ 950 us
timbersled - 40 lbs $1500
chromoly sub frame - 12 lbs $1850
cr racing post - 3 lbs $350
ti drive shaft - 3 lbs $500
ti front bumper 2 lbs $500
ti bolts - 6 lbs
I would like to put it on a scale anyone around Grande Prairie have one I could use.
In the near future their will be a diamond s ti tunnel , a boss seat, under tunnel exhaust dump and light weight side panels. That should will get me to the 100 lb mark for around 8000 grand.
ti bolts - 6 lbs
I thought the sub-frame was only 6 lbs max. did you weight the two ?
Cheap lightweight job on mine that worked very well. Put 08 Cat rear float skid, built aluminum drop brackets and modified tunnel extension like the 2010 Nytro with a 162 Camo and put a tunnel dump exhaust on the midmount turbo. Lighter to lift on backend than an M8 now. Estimate about a 40 lb loss and have a timbersled front coming for it as well. Handles and rides better now than the cat I took the skid out of. Parts to do this were all laying around my shop and only took about 3 hours time to do.
ti bolts - 6 lbs
Add another $3000 for a tunnel and that equals another complete sled.
do a search for nytro diet....lots more info on that thread from old, and not all titanium stuff either...
Yes sir it would. But the smile on my face every time I push the flipper = priceless. 2 stock sleds would not equal this much fun.
GOTTA LOVE BOOST!!:D:D
