Nitro MCX 18#'s on av gas (100LL)
Sleds R Fun
So I'm hearing lots of talk on Nitro's needing some motor work with any amount of boost.So what do you guys think?
I have a MCX stage 2 with head shim and run 18#'s of boost on av gas @ 3000-5000ft. Am I sitting on a ticking time bomb?? Sled has 1400 miles boosted right now.
Boost calculator asks for 97.5 octane at 3000' using 18 psi. I would say your within margin.
I was instructed that the motor stock is ok to 15lbs with 100% 110 race fuel, above that you should look at rods and pistons. I would think you are close to the max boost before motor work is needed.
I know people running 300+ hp with stock motor. MCX stage 2. Don't know the boost but would be close to 20 psi.. No problem so far that i know off..
