Has anybody tried the NGK Iridium BPR9-EIX in a 2012 Pro 800 RMK,good, bad or indifferent?
Do the 800s foul plugs when you use extra oil?
They are more susceptible to fouling when you add oil but it depends on how much you add. But I honestly would rather foul plugs all the time then run with the stock oil to fuel ratio.
I just picked up a set of these plugs....They had a 4 digit number under the BPR9-EIX does that make a difference, I picked these up at the local part house instead of the dealer to save a few $$..hence the reason to run an Iridium plug. No fouling.
I run BR9ES in my 11. Runs fine.
Is this Ok to run.
