P
prairiepowderhead
I like last years better still. The look of the ground clearence made z-bros very different from a distance.
Finally someone decided to use a ball joint instead of a tie rod end. Yay!
Skinz, are you seeing this?
Looks good but I think Skinz is still the way to go since they actually change the shock angle as well. Diamond-S, Z-Broz ect all have +3 front ends but you still end up with vertical shocks. Converting shock to spherical ends is expensive but IMO, it's the correct way to run a "forward" a-arm.
I am rather dissapointed, had my name on a set for a couple months now waiting to see the changes but would way rather last years setup. Where can i get last years ?
Did the older a arms use a longer travel shock?
