new to turbo and trying to tune it need help
I purchased a 2011 rmk assault from haydays it has a boondocker turbo kit on it. I have clucthed it for my altitude around 1000 feet. I also have a low comp head from boondockee on it. The non ethanol key in it. It has the ekey3 timing key in it. The issue I have is that in about a half hour of total riding if not less I went through 4 sets of spark plugs. It runs as far as I know great for a bit then It keeps dropping a cylinder change the plugs and its fine. Twice on the mag side the spark plug it self lost spark. I swapwed A diff one on in and that one sparked fine.the. plugs have black soot around the threads. The electrodes have no color because they are not ran long enough. Does any one have a low elevation tuning table that works good? Thanks in advance plug gap is .024" premium non ethonal gas. 6psi boost.
I'm not a turbo guy yet, but things coming to mind include overfueling in that rpm range, intermittent electrical/ignition issue. Sounds like a wet foul to me, but losing spark sounds electrical.
Hopefully someone else will chime in here. Sorry for the problems, stick with it and you'll get it!!
Well I run at sealevel(0) to 1200ft. I have a few things for you to try, first off, is it just straight pump gas, ALL the 91 premium I get is tested on my octane tester at 86-89.... I never had any success running anything over 4.5-5 psi of boost. I would be adding some octane to the mix for security. Is it intercooled?? If not I would be definitely adding Octane, even the boondocker Air/Air is kind of shady without LOTS of airflow(Venting). Water/Air at sealevel is the way to go.
Second, gap the plugs down to .018". Run BR10EIX - Iridium, I can almost get an entire season out of one set running 50/50 pump/116 at 12ish#'s @ sealevel. Next what is the AFR's or EGT's at Wide and Part(Cruise) throttles. Mine likes a 11.8-12.3 at Wide open with boost levels of 4.5 - 6. They like a lean cruise, 13's, my stock motor was into the 14's, but I guess this was for emissions.
I also went up 4 grams of weight from what boondocker recommended, I was hitting the rev limiter all the time.... Not good on plugs and pistons. The det light will be flashing at you if this happens.
I also found my boondocker box to be inconsistent from day to day depending on Barometric pressure, I'm in newfoundland so air moisture content is high here as well. Plays with the tune, if you live in a naturally dry climate you might find it to be more consistent. I changed to a vipec for more control. You might want to varify that the timing key is working properly with a timing light, it should progressively pull timing toward the top of the RPM band. To a max of three degrees. I think... I'm sure this is how it is supposed to work...
All things to check out. Give me abit more info, I'm at work now, but my woman has my tuning bock, give me your temps, Baro pressure, and I can tell you what my settings were on that day, but again, my weather is alot different and each persons location, climate, dictates there tune will be slightly differnt then mine.
I had a steep learning curve, still learning, I never had any help with my sled, Guys like to keep there tunes and what works for them a closely guarded secret, I however do not race, and don't really have any desire to keep secrets. :) If I can help, I will, there are alot of knowledgable people on here, with any luck they'll pop in and give there two cents worth as well.
When you pull the plugs, are they wet, or just dont fire? Easiest way to kill a plug is overfueling. When it fouls, do you check to see if you still have spark in the old plug before changing to a new one? Try to eliminate possibility of ignition problem first. Then look at fueling.
here is the full info on the sled as much as I know
I purchased it from Western Power Sports at haydays, it has 774 miles on it, I talked to boondocker as soon as I got home and had them send me the white/almond primary spring, and 1072 weights, and there low compression head (10.5:1) suppose to be able to run 7psi at sea level on premium non ethanol. the turbo kit on it has the ebc, boondocker box, and turbo non intercooled, the ekey3 which I verified by testing it per them. I have not verified it to work yet with a timing light. I will be running it around 1000 to 1300feet
what I found today
it is 21 degrees Fahrenheit here 56%humidity 30.18in pressure
I leaned it out quite a bit from the factory tuning that is in their online instructions and it has seemed to help the machine has no egt or a/f gauge on it I may need a a/f atleast. when I leaned it out it started to overboost badly like 12psi rather than 7Psi but It seemed to be alright on the plugs didn't foul one. I richened it up some and now it maxes at 8psi doesn't hit DET but is back to fouling plugs. but now it seems like if your easy on it the plug will come back alittle but never all the way. before it wouldn't even idle on that cylinder now it will idle on it. when I take the plugs out the cylinder it wouldn't fire on the plug would not spark. swap a new one and spark is there. the ethanol key is in the 10% right now that got rid of the det problem I was having at one point in time.
here is my fuel map as of now
lo md hi
xtra -4 -4 -9
4300 00 00 00
5100 05 09 12
5900 13 20 28
6700 15 28 30
7500 13 30 30
8200 17 26 34
8500 14 28 34
the next part I do not know what it means I would like to
rpm al dr sn
acell 00 00 05
I appreciate all the help!
the plugs are never overly wet they have been damp but not soaked
Ok, well I think your on the right track, but there is something that I find abit wierd, your boost pressure is all over the place.... This is definitely not normal and is going to throw the tune out. I would do acouple of things, varify your wastgate spring break pressure. This can be done with a pressure pump, any automotive store should have one, I got mine at Canadian Tire. If you have a boondocker adjustable wastgate, back it off all the way, the actuator should move at around 4PSI. If it has a non adjustable wastgate, they are 7ish or 4PSI. I would unplug the EBC solenoid or just pull the two lines off and join them with a hose joiner, should also find that your local Auto store. 1/8" should do with acouple of zip ties for clamps. What this will do, is remove the EBC from the equation and allow the sled to run the wastgate spring pressure, 4 psi or 7 depending. Once you have a consistent boost pressure, you can begin to tune affectively. Lower the better to start.
You could be drowning the motor in fuel, hence when you leaned it out it started to boost erradically. You need to get that under control. With 91 Octane, non intercooled, your fuel will not support 12#'s and I would expect catastophic failure sooner then later. I have pistons to prove what excessive boost and low octane can do....
From what you said about the clutching, it sounds like the sled might have been setup for a higher altitude..... Get that boost under control then we can work from there.
Do you have access to your map numbers yet? I'm wounded if its just so far off yet that it's still boosting erratically. Do you have something I can try just to see that I'm in upper Michigan right now and when I go home layer today I have no snow to test on. I have a pressure pump at work so I will check the waste gate when I get back. Thanks again. Also just noticed at the end of the day it got to 170°F and stated pushing coolant out the overflow. Now the level is right at the bottom if the bottle. What temp is too hot for these? Or is a gasket bad? Thinking that needs to be addressed first I guess. It doesn't seem to be burning it at all though. No white smoke or smell of coolant.
Good advice.
If it was me, I would get the pump gas out of it and some race gas on it, until the sled gets happier. It might save you a catastrophic failure.
I don't run my sled over 140.... But that being said, I have pushed it to 170 before, going home, on icy days, not getting into the throttle at all... and I'm usually on empty... I recently, last year put a terra Alps thermo kit in the sled, it is alot better now, temps are stable at around 118, and I have redline water wetter in my sled as well, to help thermal transfer of heat. The sled will run hot with boost.... Well they run hot anyway in low snow.... I would be upping your octane, it is costly to build a motor..... Especially when t6hey like to crack ring laqnds and spit them out in the bottom end, or out through your turbo... Both of which I have done.... My engine is at Indy Dans now....
OK I will get some av gas. Do you have any idea where my coolant would be getting pressurized from? I seen it coming out the over flow at 170 but before that and It wasn't pushing it out I could take the cap off with no pressure in the bottle. Like 120°F at that point
Well, there are acouple of ways to pressurize the bottle, in most sleds and turbo sleds, you are actually boil the coolant(turning to steam) thus pressurizing the system... Other then that, base gasket, head gasket, cracked cylinder, all of which allow combustion pressure to enter the coolant system. With a turbo sled, car, what ever, if you are running at normal temps then get into boost and can literaly watch the coolant temp rise, then you have a issue somewhere.... If you are running the sled all day and then on a icy run home she is gradually heating up, then boils over, it is likely thermal expansion/boiling of the coolant. Pretty easy to test for really, there is actually a little kit you can buy that test for combustion gases in the coolant, liquid changes color. Or there is a white creamy froth on the top of the bottle. But this is in the worst case senerio for the froth, milky stuff... If you take the sled for run and get into boost and she gets hot fast, bet on a base gasket or head gasket o-ring. Also while your at it, check your reeds, non intercooled after a good hard pull could produce 200+ deg F of intake temps.... I actually have a boondocker Air to Air intercooler with Fan. I won't lie, she got about 3600 miles on it, but it still does the job, could be interested in selling.
Woman is working, numbers are on hold till later...... :) But from what I seen your not far from where I used to be. Do you have the sheet that boondocker supplies with the stock numbers.... Maybe they have been played with before and are out of wack.... Might be a good idea to go back to basics...
When the coolant came out I was riding around the yard in low snow condition to try and clean the plugs out. will it limp like the older sleds after a certain temp? Maybe that was what I was thinking was my "fowled plug" issue this last time. It was boggy and wouldnt rev out. Or will it tell you over temp?
I don't really know.... I have never had it read over temp.... There is a light I think... Not that I can ever remember seeing it on.... The sled will back down with knock, I'm sure it'll do the same for coolant... If not its pretty stupid.... I'll be honest, it has been two years since I have run the sled over 140. Kind of a rule i made... I stop and pile snow on the tunnel and cycle the coolant till it is steady at 110-118 again. Others my find that little rule stupid, whatever, my opnion is its hot for my liking.... I'm sure there is someone on here who has seen or knows when such a system will activate. My Vipec has safetys programmed for this type of event....
When the coolant came out I was riding around the yard in low snow condition to try and clean the plugs out. will it limp like the older sleds after a certain temp? Maybe that was what I was thinking was my "fowled plug" issue this last time. It was boggy and wouldnt rev out. Or will it tell you over temp?[/QUOTE
1 Pressure test cooling system with a coolant system pressure tester.
2 Make sure cooling system is purged of any air bubbles
3 Compression test
4 New plugs
5 Air intake clear and unobstructed
3 Try testing the sled again at 110-120 degrees not over 140 degrees. With avgas or race gas mix to get you around 100 octane.
IMO this where i would start just make sure, you have the basics covered before going into more detail.
