new to hill climbing
ullose272
3,372
965
boise idaho
So im thinking that i might want to try a hill climb race. do they have novice classes? I used to race motocross at a local pro level so racing isnt new to me. i just dont know where to start or where to look. any good info out there?
Somescreenname
545
76
Go to RMSHA.com, they will have a lot of information on there and you can figure out which level/class you would want to race.
  • Like
Reactions: Racer220
Racer220
685
43.463558, -110.762496
Bumpity for anyone that has questions. Tis the season of giving right?
Also mentioned in some other posts is finding the races that offer an Amateur class. Probably the most effective way to experience the rush of racing up the courses.
Racer220
685
Where would you find some plates or stud kits for more traction?
What he said ^^^. NO STUDS ALLOWED in the hillclimb circuit. Only traction screws (allowed in all classes). Titanium cleats or comparable can be used in addition to screws but only in Improved Stock and Modified classes. I would double check the ISR book for clarification and specs just to be sure.
Racer220
685
KoldKutter
You can run as many as you want. Basically try to avoid putting them anywhere they could rub through on the coolers and cause a leak. My advice would be start with tunnel protectors right off the bat. Keeps the overall damage to the inside of the tunnel to a minimum. The Doos have little slots that they slide into. not sure about the other brands these days.
