New Product: ZRP - GEN 4 TAILSTANDER ADJUSTABLE WEIGHTS
die hard poo
1,177
796
Kenai, AK
Update for 0-3000ft elevation tuning:
ZRP Tailstander 85G base weight:
Added 2G to each hole initially (total 6g added) and was hitting 8100-8200 RPM on spring snow. Added 1G to tip hole (total 7G added to a total of 92G) to drop RPM a bit, now hitting between 8000-8100 RPM in a bit deeper spring snow. Going to add 1G more to tip to get between 7900-8000 RPM hopefully.
Initial impressions seem to be good, no overly crazy improvement, but the clutches do seem to be a bit cooler and slightly better throttle response and RPM consistency. Time will tell if my belt will last longer than 300 miles. Still stock secondary.
P
Nov 28, 2007
1,795
762
Yukon Canada
We run similar weights 85 gram base 6 grams in the bottom and 2 grams in the middle is what I like a little more positive engagement about 200 RPM lower than with the weight in the middle and tip. Also maintains the top end rpm better at the slightly higher elevation last ride was 4 to 5 thousand.
So far definitely my favourite setup, even though the SHR set up works not to bad either. Waiting for a few pieces for my second sled to go ZRP as well.
  • Like
Reactions: LPIdaho
justinkredible56
1,048
362
83
Eagle Mountain, UT
I saw a “Gen 2” version of the tailstander weights listed on their site.
I’d like to know what the difference and benefits of the second gen are but there isn’t much info on them on their site.
  • Like
Reactions: PaulAnd
ZRP Engineering
737
382
Utah
Our Gen 2 850 Weight saves 45g of rotating weight vs our Gen1. The profile and shift force are identical to the previous weight but with better throttle response. All of the weight savings is from behind the pivot pin; in front of the pin is identical to our Gen 1.
So new 75g performs the same as our original 90g.
PaulAnd
2,186
586
Northern IL.
Not quite getting what your saying about the weight..
So you are taking weight from behind the pin.. get that, but how does an overall lighter weight control RPM?
Wouldn’t you still have to add it back to Pin, Mid or Tip?
For 85g -87g stock sled
7-10k
ZRP Engineering
737
382
Utah
7-10k
Because the weight in front of the pin is exactly the same, so it produces the same amount of force into the roller.
Sent from my SM-G950U using Tapatalk
  • Like
Reactions: PaulAnd
PaulAnd
2,186
586
Northern IL.
So order the 85g for 7-10k?
I think I remember Big John liking tip weight also, so what tip weight would you recommend before installing?
Cant change tip weight on the hill right?
But can change mid weights on hill?
Thanks for the help!
ZRP Engineering
737
382
Utah
Yes 85g would be best for you. I would add a 2g magnet to each hole to get to 91g and you should be about spot on for that elevation.
  • Like
Reactions: PaulAnd
live2beel
486
83
So I am confused:face-icon-small-dis. So the gen 2 weights won't work on a stock 850 at 7-10k. Is this a turbo weight. Empty these would be like running 90g on version 1weight?
ZRP Engineering
737
382
Utah
We only have the 75g Gen 2 weight at this time which is the right weight for high elevation turbos and low elevation stock sleds.
Stock at 7-10 our 85g Gen 1 weight is the ticket!
Matte Murder
3,579
2,258
The info is probably here but I’m probably lazy or blind so I’m asking.
ZRP. I have an 18. Stock set up I blew a belt at 300 miles. Dealer did the softer secondary spring and added weight to the bolts. I think a 2mm washer to each bolt. Sled ran stronger for rest of year. Had about 300 miles on the second belt which still looks great. Dealer did the engine mount update and primary spring update for free. I also got the new vented clutch cover set up. Have not tried those mods yet.
What would you recommend for my 18 850 175. Mostly ride 3500-6000 in heavy coastal snow for the most part. Also ride out east lol at 7000-10,000 a couple trips a year.
If you were holding my credit card right now what would you recommend for weights? Would you change either of the springs I am running?
ZRP Engineering
737
382
Utah
I do not have enough data to make a complete setup recommendation for the 3-6000 range except that the optimal weight to start with for that elevation is our new 75g weight. This weight will work for the higher elevation as well but will not be quite optimal as it will need to be run empty(no magnets) to pull enough rpm at 8000ft+
  • Angry
Reactions: 02sedona
live2beel
486
83
So when will we see a lighter gen2 weight for NA sleds at elevation?
T
Oct 14, 2018
7
I have a 2018 G4 165 3 inch with a Silber Turbo running zollinger 90 gram base weight and loaded heel middle and tip sections to achieve 8000 rpms at 5 psi I’m running silber primary spring 170-350 and secondary 180-303lbs I want to try 7 psi but need more weight to stay at 8000 rpm with added boost any suggestions?
PaulAnd
2,186
586
Northern IL.
Just a follow up..
I was pulling 7900 behind the widow maker..
Pull 2 ounce from the heal? Or middle?
Or just leave it?
Thanks!
Fresh belt and clean clutches
No 19 tooth gear yet Kandog!
Soon!
