M
mike_s
So are you saying Bullydog designs and builds the box that H&S and others use?
X2.
Bryce,
What "modules" so far has BullyDog unlocked ("hacked") on the Factory Polaris map?
Does the BullyDog "box" have the ability to reflash the ENTIRE Polaris/Kokusan map?
How much programming control is BullyDog giving the shops that have purchased a dealer agreement with them to date?
What possible challenges are you seeing in using these on boosted sleds, SO FAR, this coming season?
Are all the bugs worked out for Turbo use in your opinion?
I think this is pretty darn cool... the ability to adjust timing based on different sensor inputs... and modify the base-map to cooperate better with a turbo system... COOL!!!
Thanks in advance,
MH.
.Bully dog has done a good job unlocking the full factory ecu with all its hex files. so anything that is in the stock ecu is there. All the basics have been disected. timing, fuel management. exhaust valve open, closed and steady state in every aspect. There are how ever some mapp and things in the stock ecu that we dont know what it does yet. Its not because we cant figure them out it is because we dont have enough time yet on the hex break. In time all will be there. We have total control over everything so far.
How it works right now is this. We build a map you install it on to the sd card and down load it in to the ecu. now your ecu is reflashed to the new map and it will be reflashed until you do another reflash to it.
