That's where mine is wired into and it works great. I only have one though.
Is there anyone that has some succes with mounting LED lights from the DC plug in the headlight harness on the PRO-RMK.
I have done that install and the lights work but they are far away as bright as they should be.
so i guess there is some issues with the power, they are on 0,83 amps each witch is 1,66 combined and there is a 2 amp fuse on that DC plug.
Any suggestions?
I would recommend going with the twin light setup if you can. LED lights are very powerful but their downside is that the light is mainly projected totally forward with less peripheral light which is important to me when I'm out in the backcountry. These look like really good lights and I appreciate the 2 photos that were posted.
How would you go about mounting one of these up if you wanted to have it in addition to the stock lighting?
Phatboy...
Regardless of what the turbo builder has told you.... I HIGHLY recommend Against using the red/yellow with a larger fuse (Acc pwr) red/white (DC TEST power, inapproprately labled "DC PWR" ) for ANYTHING but very low draw items.
Do not run anything into the "DC PWR" . This is a DC TEST port... unfused and also powers up vital components like the ECU etc...
Are these Cyclops Lights?? We want to know about any issues.
