Here’s my solution for trying to actively manage under-hood heat. You *must* have a WRP/”Madsigntist” or WildChild gauge relocation bracket for this to work.
This fan is modified to be waterproof to IP55 standards. That’s not to say the fan will not fail due to water or dust ingress, but helps minimize the potential. The electronics and the field coils were encapsulated in a UL recognized MIL-I-46058C polyurethane. A synthetic grease, used on Mil/aero fans, has been added to the bearing shields and shaft to prevent corrosion. Polyurethane was also brushed on the stator to retard corrosion.
This is a direct plug in- there is no cutting, drilling or other modifications of the snowmobile required.
The fan moves 67cfm of air and only draws .38amp of current and comes with all necessary hardware and step by step instructions. All you need to do is remove your hood, 2 bolts, and install. Total estimated time is roughly 30 minutes. Maybe more if you have a few malted beverages.
SEE MY AD IN THE SWAPMEET SECTION FOR PRICING, SHIPPING/AVAILABILITY AND SALES RELATED INFO.
http://www.snowest.com/forum/showthread.php?t=357204
What does everyone think is the more effective way to reduce underhood temps? Active ventilation or passive ventilation? Or a combination of both?
Looking forward to a good discussion and what people think!
http://youtu.be/GMQ86BoRmHs
![canadsledpartsinstall.jpg canadsledpartsinstall.jpg](https://www.snowest.com/forum/data/attachments/182/182039-247bf8e33fcaef87640f40839825ff26.jpg)
![20131102_233125.jpg 20131102_233125.jpg](https://www.snowest.com/forum/data/attachments/183/183870-e65cad13baebff824ccbd3700f3fcceb.jpg)
