new Problem with the 900
I have an 06-900 and replaced the fuel line because it would bog really bad broght it to the dealer and he found the line had fallen apart in the tank so brought it home and had to wait for snow finally got some and took it for a ride had to pull it like 5 times to get it started cold(let it warm up to 100 deg ) went for the ride rode it a few minutes and the bog is back not as bad but it won't pull anymore than 6000 rpms so turned it off let it cool down a bit and tried to start it and it took 8 pulls to start and sled still bogs anyone have any Ideas what would cause this
Intake boots Plugs and wires
throttle switches there are two in the block
Exhaust temp probe..bad/slow = no codes
Exhaust valves/bellows/springs
TPS adjustment
fuel pressure
Thats the short list...I am sure there will be more suggestions keep looking..let us know.
the dealer called and said fuel pump is bad only has 60 lbs of pressure and it need 116 lbs of pressure so he ordered it and is waiting for it to come in and I will keep you guys posted on the progress
