You're asking about better handling the taller the keels. I went taller to hopefully address ski washout. Steering will probably be heavier. Haven't tried new ski yet, finished it last night.
Just thinking out load here, what about making the outer "runners" out of stainless steel angle. I just think that the thickness of the UHMW will create a lot of drag. What do you think?
Are you noticing better handling the taller you go?
The hole for the 3/8" bolt is 7/8" from the bottom, measured on the inside to hole center. Hole is centered in saddle which is 5.5" long and 3" wide inside. 4 bolt pattern 4.75" x 2" I've quit experimenting with ski for this year, waiting to see Alan's new ski at Schweitzer sledfest.
So Did anyone get a look at Timbersled's new ski?The hole for the 3/8" bolt is 7/8" from the bottom, measured on the inside to hole center. Hole is centered in saddle which is 5.5" long and 3" wide inside. 4 bolt pattern 4.75" x 2" I've quit experimenting with ski for this year, waiting to see Alan's new ski at Schweitzer sledfest.
any one try one of those USI with the big rudder on the back of the ski??
