New bog developed 2013
sbosmt
New member
Oct 14, 2008
134
2
18
Bozeman, Montana
I was riding my 2013 m8000 this weekend and halfway through the day my sled got a terrible bog. It would not go above 58-6000 most of the time. At lunch I pulled my plugs and the clutch side were dirty so I replaced all 4. No change, so I just ride like that the rest of the day. Once in a while it would open up, but mostly 5800 was max. It is stock other than a can with 2700 miles. Pulled the power valves today and cleaned them, they were dirty but seemed adjusted correct. Where else would I look?
IDspud
4,096
Oakley, ID
Just dirty can do that if sticking.
Your stated rpm is right where dirty pv would act up.
kanedog
Undefeated mountain clutching champ of the world.
3,116
3,892
Check for broken primary clutch spring.
Betterview
235
89
Central Minnesota
Check the reeds, You might have have a petal that has a large crack but has not broken off yet. 6000 is about the spot that a partially stuck or broken petal causes the cylinder to misfire.
sbosmt
New member
Oct 14, 2008
134
2
18
Bozeman, Montana
Ok I'll look at check spring and reeds. Do I need a scope to see all the reeds? It sounded different as well, deaper almost like a 4 stroke.
kanedog
3,116
3,892
Reeds bad on the cylinder that were fouling. Of course local dealer had none in stock so I ordered boyson.
Woohoo! Great suggestion Betterview!!!! Snowest forums to the rescue!!’
