Was out riding the other day, tried to start sled after it was parked for maybe 30min while we had lunch and nothing. I hear a 'click' coming from the right side, but that's it. Ended up pull starting it manually using a cord around the primary, let it run for 15min before trying to e-start again and worked fine, worked fine the rest of the day. Had a similar issue the next day where it wouldn't start, but after pull-starting it went fine and then started fine the rest of the day, even after sitting for periods of time.
The fact that it's so inconsistent is puzzling. If it was the battery, I'm assuming it would be fairly consistently an issue. Any thoughts??
