Will the billet handle be available to adapt to the old style?
No, they are similar looking, but not interchangeable.
Make a fully detachable double allen bolt clamp. One that will fit over a grip and can be attached without taking everything apart. Then drop the price in half. Gold fingers are $99, work perfectly and have a name behind them to help sales. Not a trash just a fact. Years of watching cool bike industry accessory makers go tits up trying to compete should be a lesson.
Best of luck, I hope it works.
OK.
Lets compare these out.
I can do that with out bashing the competition.
In fact, lets look at all the dual throttle kits available.
Mine is a 2 piece clamp with 2 allen screws. You can see them in the pictures.
That whole front part comes off. No dissasembling of the controls needed.
I'm not going over the grip any more because too many people are crushing their hand warmers with that style, so I have mine only taking up 1/2" of bar space. You can find 1/2" on 99.9% of the sleds out there today.
You are right,
Gold Finger is cheeper, much cheeper.
Look at what you are getting though.
Don't get me wrong here, they do have a safe and reliable product that does everythhing it needs to to work and all, mine is just that much better.
Their's is a cast aluminum lever, and being cast, it's not going to be nearly as strong just by nature of the materiel. Mine is CNC'd from 6061 Billet in Meridian, Idaho. HUGE difference there alone.
Their short lever does look extremely cool, but then when you go to use it, you instantly find out that it's basically a light switch in that with the short lever, it's very hard to modulate the throttle. You find your self either full on or off with it, no in between where you can actually finess it through a tough section. The other drawback to the tiny lever is that you can miss it when you are in a pinch and need it, especially with big gloves on.
Now look at their cables. Straight black Huffy bicycle cables and not seeled at the ends either. The end of their cable is exposed to the elements where it can and probably will freeze with moisture (we ride in snow)
Mine are a stainless cable that's PTFE lubed to stay smooth and repell water based moisture. My housing is compressionless and Kevlar braided. It has sealed ends to keep the moisture out. Then I went the 1 step further and put the rubber accordion boot over the exposted cable at the right side to keep all of the cable from being exposed to the elements.
Now for adjustability,
Theirs has the same barrel adjustment at the lever that I set up with through this season. Their adjustment is a bicycle brake adjustment as they have used Dia-Tech levers (just as I did) for years. Then they designed ther lever after that same bicycle lever, but with a modified mount.
I found that the weekness here is that with the cable secured into place, the adjustment didn't adjust much at all if any, so I'm setting this model up with an inline adjuster at the other end of the cable where it will work much better for this application.
Again, I've gotten away from the bicycle design and went to an actual motorsport design with the shape of lever that works for this application.
Our right side adapters are pretty similar. Mine is stainless as is theirs.
My right side is a little more compact and cleaner though.
My throttle is just a MUCH better unit, and it's billet.
Now lets look at the rest of the dual throttles out there.
My favorite of the competitors throttle kits is the
Snobunje.
Theirs is also with a lever that they (Rick) designed specifically for it.
It's a longer lever and it modulates well. I think it would work better if it were shaped with a double bend style to make it harder to make the "oops, I thought it was the brake" mistake.
Their lock-out is a quick disconect at the right side and that works well.
Their right side moves with the thumb throttle back and forth on the cable though, where my right side adapter sits independantly of the right side until you use it. I think this difference will make the right side of my cable last quite a bit longer.
Again, I have the best cables that are sealed etc. No one else covers these details.
All in all, they have the throttle I'd buy if I weren't building mine. I think theirs is almost as good as mine, but again, I think mine is better.
Retail on theirs is $149.95
They are a good company and also friends of mine. We compete, but we don't bash each other. They are just good people.
Lefty Brand has theirs for $100 and it also works well.
Small thumb flipper on the left looks identical to the Powermadd Powder throttle and that looks really nice. Again though, it's a very small lever and I think I already covered my issues with that.
Their right side does move back and forth on the cable end when you use the stock right side throttle and I already covered my thoughts on that aspect.
Their cables are better than Gold Finger's, but not sealed up or as nice as mine.
Allen is also a very good guy and has a good company.
His throttle is reliable and safe, but I think mine is just better.
Powermadd stopped making theirs this year because on theirs you had to disconect the micro safety switches in your throttle block. Otherwise when the left side throttle was used, it opened up the carbs while the stock right side throttle stayed in the closed position. Then the safety switches would "think" the carbs are frozen open and shut the motor off. This made theirs my least favorite, even though it was probably the cleanest looking.
Retail on theirs was $159.99
Kinetic had a really nice unit for a good price, but they don't make them any more.
I heard that it was a 2 person partnership and one of them either died or got very sick and dropped out of the business, causing the other partner to lose interest and drop out too. I'm not 100% that this is what happened, but I think that was the story.
They were the first to use the Dia-Tech Gold Finger lever, but in red. They had a good product and all too.
Too bad they dropped out of the business, with competition, the consumer always wins as competition makes the MFG's actually compete by putting out better products etc.
That leaves
SMW at $70.
I've only seen theirs once several years ago when I first started building mine. (I bought 1 of every model available at that time for comparrison reasons)
They have a right side adjuster and that is very functional and cool, but I REALLY hated their right side mount for the adjuster.
I'm not sure what their current model looks like or IF they've changed it at all, as I haven't done a comparrison with theirs lately.
So this leaves mine as the most expensive out there by $40 over the next most expensive.
Just like my extended cables though, they are also the most expensive way to go longer, but also the highest quality available today, and I sell a litteral ton of them and have requests for more models than what most could ever imagine.
You get what you pay for, and I'm paying out dearly to have the absolute best product available today in the dual throttle market.
It goes on a $10,000 plus machine and so it needs to be the best.
