I go about #270 geared up and did alot of reading on here about 07 144" switchback suspension setups over the offseason and played with it. So here's what I've done: Upgraded rear torsion springs to .375/49's, added #225 front shock spring w/about 1/4" of preload, rear reservoir shock clicker adjusted 5 from soft, limiter straps in middle hole, and front ski springs with little preload. I'm wondering if I overdid things with the upgraded front track shock because I am getting quite a bit of inside ski lift in the corners.
Any suggestions as to which areas I should adjust first with this set up to get a little more pressure on the skis. I have the rider select system and pretty much ride with bars in the 5 position all the time. I'm also running 6" carbides and have shimmed the skis so steering is spot on.
Thanks guys!
Mark
Thanks guys!
Mark
