Hi all,
I have a somewhat unique question that I'd like your input and advice on, since I know virtually nothing about snowmobiles. So I'll try to pick YOUR brains about what helix and spring to use.
What I have is a little racecar that I run in what's called autocross. They take an open area like part of an airport and set up orange traffic cones and make a small road course. The total length of the entire course is usually about 1/2 to 3/4 of a mile total (sometimes a little longer), with usually about 12 to 14 turns, so you can see it's fairly tight.
The speeds aren't all that fast (maybe 65 - 70 mph tops) because you're really always turning one way or the other. It's more about driver control than speed. Probably the longest stretch of straight-away is 100 feet or so to 'open her up'.
So I guess I need the driven (secondary) clutch to upshift fast and backshift fast so I can 'goose it' coming out of a corner but yet backshift quickly as I'm going into a corner to help slow it down and also be ready when I 'goose it' coming out of the corner. Does that make sense?
There's no snow or hills to contend with as a snowmobile would have, just flat concrete or asphalt with lots of turning.
The jackshaft is keyed and is 1" diameter. It currently has an old Arctic Cat button style secondary that I plan to replace with a newer style Arctic Cat roller off of Ebay fairly cheap... unless one of you guys wants to sell me yours cheap.
Any suggestions on what helix and/or spring to use?
I'd appreciate any ideas/suggestions/input you might have.
Thanks!
Thanks!
