nEED #'S Bondockers
N
NITROSKIDUDE
05 RT 1000 with 06 program, CS, twins everthing else stock!!!
Any one, all the old RT threads gone on old forum.:mad:
im running the same set up with the timbersled airbox kit. I ran a couple days last year on cs's base settings and it was very rich. I've done a little more tunning and think its running pretty good now, (im by no means an expert tuner) i'll post some #'s tonite when i get off work. i know im about +18 w.o.t. at the 8100 setting. do you have thier n2o set up as well? do you know if we can still mount the bottle in the normal location with the twins?
First off, I'd STRONGLY rec that you get the 07 mid-alt programming. You'll then really get the benefit from those twins.
Mine were all in the 4-8 range with 10 in the 5000 and 6,700 mid and hi
Make sure that you tune with some pyros
Crankshops numbers are fat. They don't want calls on meltdowns
3000- 2-4-4
5000- 6-7-7
6000- 8-5-10
6700- 10-5-9
7300- 4-6-18
8100- 4-5-18
hope that helps. i ride from about 3000' to about 7500' and it seems to be working well. id see 1175 on a long pull.
