Need info on pump gass turbo kit for M1000
1
1100Cat
Have been sending emails and phone calls out to the turbo guys/companies on a pump gas kit for the M1000 with no luck. Have been told by the ones I have been able to contact that there is no pump gas kit at this time. Been told this is because fuel system not capable of supporting it and the M1000 has no deto sensor like the M8. I have heard that both Shain Stanger/Brad Story have been working on one but have not been able to get a hold of Shain for some info. Shain or anyone if your reading give me an email or pm. Or if anyone has any info on any one that is offering the pump gas kit for the M1000 give me a shout with contact info. Any help would be appreciated
ogden valley sports is possibly coming out with on, i believe the price is gonna be around 4500. it runs an aero66 on 5psi making 220 hp on pump:D
Well like stated in several other threads being her in B.C our race fuel runs anywhere from $12-$18 a gallon. Not only that even a pump gas M1000 around 5/6 pounds of boost is going to make around 220hp at elevation and no 1200 is going to make that at elevation. 3% lose for every 1000 feet and ride at 7000 feet is going to put a 1200 down roughly 20% of its power. 1200=lets say 230hp minus 20%=46hp-230=184hp at 7000feet while a pump gasser will make still over 200hp at that elevation. Also the kit will be going on a 1200 big bore already so big bore power with adding even more on the boost if it becomes available for the 1000.
Ogden Valleys number is (801) 745-3833 Talk to Garr. He has a great setup for the M1000.
Hopefully you got the 1200 with the port timing for the turbo.
if your worried about the gas prices i run 100ll octane av gas in my sled i just get it at the local airport and most times the 100ll is just as cheap as regular 87. the airport pump and pumps in town never go up and down at the same time so when av gas is as cheap as 87 i go stock up. the airport usally stays at the lower prices for aorund two weeks then goes up to par with everything else. like this may long weekend we just had pump gas went up but the av didnt
What are max boost levels that can be ran on AV Gas on a race fuel turbo kit. What is the octane of AV fuel and is it all the same from airport to airport.
