Need help with set up
I am on a pro 163. I weight 210 without gear. Could you guys give some info on where your front and rear track shocks are set as well as where the limmiter strap is set. I took her out for a bit yesterday and it wont steer on ice and all susp felt stiff. The prev owner has the front shocks threaded down about 1-1/4" and limmiter all the way out. I think i should reduce both the front and rear track shock tensions first as when i get on it in my heated garage the rear susp doesnt move down(sag) at all!
Another thing i need help with is clutching. I am sure it has stock clutching in it. I will end up riding it from 3-9000 ft. When i rode it yesterday it would pull 8300 rpm. My current elevation was 3000 ft. I think i need some primary help. It needs lighter weights so when i get to elevation it will pull 8300 up there. The pri spring is black with white numbers on it but no painted line. Any help would be greatly appreciated. Thanks
edit: the front trck shock is threaded in about 3/8" and the rear track shock is about 1-1/2"
