Alright....just bought this Nytro two weeks ago. Before I went out, I installed a Ballistic lithium-ion battery, and a Yamaha roll-over valve with tether. Then I made my own steering relocator (works great!). This is everything I have done so far, just to inform you all of all the "variables"..... and I should mention that it has a rumble pack exhaust and HID lights.
Now, back to my PROBLEM.... First time out i made it two miles from the truck and when I would open the throttle it would bog out, similar to a two-stroke hitting a det-sensor. My two left lights (YELLOW hazard and RED temp) would come on but would turn off as soon as I let off the throttle?? I had a code 81 (grip warmer, they are NOT working) on my display along with and engine symbol that was blinking. If I turned the sled off and restarted, they went away till I rolled deep into the throttle.... Where to start??
Went straight back to the truck and went home Researching now, taking it into trhe dealer on Tuesday. Hoping I can figure this thing out before then. I already took it to my local shop and they thought it might be an air bubble in coolant or low oil. So they heat cycled my sled five times and added a tiny bit of oil. But I had the EXACT same issue today when I went out to see it they fixed it....nope.
Any ideas guys??? Is it electrical? (related to code 81)
