Y
yz400ex
I have installed this Digatron the way I was told.. Red wire to the yellow on the regulator and black wire to the engine block.. Sled running, gauge comes on, can go through the settings, but I cannot get the thing to display the right RPM. I have gone over the manual a number of times and just cant seem to figure out the problem. When I look at the manual it says that the Tach calibration will say CAL. Mine says C.AL. No matter what # I change this to, it does not display the correct RPM's. It will just change where the decimal is. If it is set at 2 or 4 like stated it should be, it will display like X.XX and if I set to anything higher like 10, it will just change it to .XXX. What is wrong here? Can anyone help me with this? It is the DT53S model and is installed on a 600HO IQR
