Need Help With A 670!!
Yes. The engine plates were different. The Summit plate allowed the engine to sit more vertical and this changed the angle on the Y-pipe too. So if you use the Formula plate, you will probably need to use the Formula Y-pipe too. Not much difference between the two.
