J
justinak907
Alright. First off, I got an 2004 800 rmk 144" VE. I'm having problems holding RPMs. Its only pulling about 7000 at full throttle. At about 5000-6000 it sort of bogs down a bit, then wont go over 7k. The checked the wieghts in the primary and there not sticking, clutches look like there in good shape all around, belts good. I previously had a coolant leak that caused a high temp SD a couple times. I put more coolant in and let the motor cool and it fired right up. I fixed the coolant leak, but now this is happening. I tried a temperature sensor bypass and that didn't seem to make a different. The motor is new and has great compression. Plugs look good. ANY IDEAS FOR ME TO TRY NEXT????? any feedback will be much appreciated.
