Head
Yes - Polaris sold several cover versions to spiff up the look of the motor. Take all the head bolts out, the cover will lift off separate from the head (it has an o-ring to hold the coolant that flows across the head)
If it's an after market head like SLP it will be in 3 pieces, 2 separate domes and a skull around the outside. If it's SLP the domes can be lifted out individually and will have a part number.
Their web site will help you determine if they are indeed high altitude heads.
SLP also sells domes for us flatlanders as I have a set on my 800. You can then replace the domes with the high altitude version for going to the mountains.
The flatlander version is 91 octane but if you use the high altitude heads at our elevation, you need the race gas mix.
