You say there are no changes in fuelpressure when at boost. I thougth the fuel pressure was supposed to rise when you are at boost. Is there not a pressure line in at top of the pressure regulator?
If you lost a cylinder, it's not running on boost and the plugs look lean when you should be rich you have a bad box. You can't fix that with an A/F gauge. Don't waste your money. Dale uses EGTs for a good reason, he talked me into going away from my A/F gauge and going with EGT's. Talk to him before you spend more money. It sounds like the diaphragm that boost tube goes to in the box(pressure transducer) is bad. I'm guessing that your box isn't sensing that you are on boost.
This is the reason way I haven't got one yet. But everyone have right to their own opinion. And I'm a newbie so I don't know s*it... just trying to learn as much as I can about this..
About the box: When im on boost, the box is flashing Green/blue lights and sometimes orange.. Or "on boost", the sled is just geting started to boost and then cuting out..
Will call Dale on monday.
Thansk BigHoe
I will add mor fuel or lower the boost to a safe level, but thats not the problem right now.. Problem is that the sled is running super hot EGT temp after a few seconds, and I can't get it to run rich.. Ofcourse I will not run it on the edge just to run high boost. Start low and crank it up later in the season.
Thats called boost creep.You might need to port the wastegate or improoove the piping to it.Have been testing a little more and the fuel system and the box seems to be OK. New problem is, I can't get it to run low boost. No matter what I do It keeps pushing 10-15 psi for a short time, even with my "low boost wastegate" like 0.5 seconds and then it starts to sound like it hits the rev limiter. ?? We are a little confused of what it could be? Probably the sled goes into limp mode...
For a short second I can really feel the insane power the sled makes!! Just need it to run good for more then 1-2 sec...
You can try to attach the boost signal to the middle of the pipe since the pipe have higer backpressure than boost, it will lower the boost. This way it will enritch the engine on long runs whan backpressure rice because the pipe get hotter.
