M
mccbrothers
Wondering if anyone remembers what jetting works well on the 97 Mountain Max 600 twin with the smart carbs. Ride from 3000 ft. to 7500 ft. Starts running horrible at around 5000 ft. I pulled the carbs and first dropped down to a 155 main from a 160 then the pilot from a 55 to a 52.5, went up and it ran a little better but still wanted to fall on its face after 1/8 throttle, if I feathered the throttle I could get it going wide open and it ran decent on the top end, so I thought mid range and I removed the needles during the week and the clip was in the middle position one teflon washer on top of clip and one under so I left the clip in middle position and just took the teflon washer out from under and put it on top. This last weekend back up and around 5000 cutting out popping and falling on its face, don't think it is the tor switch cause it runs great at my shop 1000 ft. plugs look great also, could it be the smart carb, or do I just need to jet it down a whole bunch more, wish someone has a good running one and know s the main and pilot and needle position for a start, please help.
