M
midwestmountain1
I just rebuilt a 2008 dragon 800 motor with 2010 cylinders.
It will start if I put slight pressure on the throttle, but will not idle. I tried adjusting the throttle cable to get more tension on the return and take out the slack, but then the idle is way too high. What is going on? is this the tps or throttle cable issue?
Also it has oil in the fuel for break in and was well oiled during assembly, it that would effect it?
Thanks
Thanks
