C
Ok so i bought a sled a week and a half ago. Its a 08 m8 with 1250 miles (3400km) looked it all over before riding and seemed to be fine at 2000ft the compression checked out at 130psi in each cylinder (checked it twice). The clutching is stock. It has a y-pipe (don't know brand as i can't see one and havn't taken it off to inspect) and a mbrp can. Nothing else all that i did different was the key was bent and broke so I cut the wires to the key/ignition hole and then taped them up and then taped them together and hid them under the hood. Also i threw some sea foam in there.I used about a 1/4 or a bit less of the bottle as it says a full bottle of it will treat 30-90 liters. At the last minute i noticed i didn't have any oil the PO ran cat and that's what i have always ran but only thing close to me was a Canadian tire so i went and bought shell advance (the only thing is not thinking i bought the non synthetic stuff). Now i have heard sometimes of mixing oil it acting different until it burns the old stuff out but i doubt that is it. I am running 94 octane from chevron along with the sea foam in the tank like i said.
There's the info here is my problem i test drove it at his house and my place more then once but never really letting on and off the throttle and it was also before i put this shell advanced oil and 94 chevron and sea foam. But i already had the wires cut for the ignition. The problem is i was going and up hill and down hill even it would do it if i let off in a corner (seems worse or wants to happen more when pointed up hill) and then if I'm barley on the throttle or letting on and off the sled wants to die and it did about 4 times on me but there's was about 6 or so other times i got it not to. Its weird if you let off when its going to do it then grab some throttle you can make it run. Also if I'm above about half throttle its perfectly fine and at full throttle it pulls 7800 rpm. Its almost acting like someone is flicking on a choke on a carb engine then shutting it off just before it dies to describe it. Checked all visible plugs and there all plugged in tight. To me maybe my best guess is something grounding out. Also i think i read about something called a TSS doing something similar to this on some cats ??
Has anyone ran sea foam and experienced anything similar to this ? I want the sled to run proper those are my ideas if you have some or know what it is it would be great if you could help. Thanks in advance all help is greatly appreciated !!!
![Yo :yo: :yo:](/forum/images/smilies/new2010/yo.gif)
![Face Icon Small Confused :face-icon-small-con :face-icon-small-con](/forum/images/smilies/old/face-icon-small-confused.gif)
