Need help!!!! Changing tunnel on 07 M1000????
D
DDD
New member
Changing tunnel on 07 M1000. Will an 08 or 09 tunnel fit on a 07 M1000 bulkhead??????
Are the bulkheads the same on all M1000 or are they different.
If a 08 or 09 tunnel won"t fit what is the difference.
Im pretty sure all m's are the same as far as tunnel and bulkhead so yes i beleive they should work
Is the main part of the tunnel damaged? If not you can just swap the 09-10' tail on, you will also need the rear cooler as it is flat on the new tail.
