Need advice.
I just tore down my 2002 mxz 800 summit 151. It had 94psi and 112psi. The Cylinders look and feel ok but is that enough to tell. What is the best piston kit? 1 ring or 2 ring, slp molly, Weseco, or spend the coin and go with rk tek! Also this may be a dumb question, but does it matter on the 2 stroke which plug wire is hooked to each plug cause I have tried both ways and notice little differance. Thanx in advance for the help. I haven't worked on a sled in 20 years. Just getting back into it. Also, the top of the pistons seemed to have a bunch of sludge or soggy ash, enough to write your name in, shouldn't that be hard and brown? Thanx guys
