Need advice about rail/suspension rmk 600HO 155"
K
KON
Hi!
I am wondering how to get my wife sled more fun to ride in the woods.
It is running like a rocket but it refuses to lift the skis up from the ground no matter how hard you pull the handlebars.
We have the limiter strap on the longest setting, we have tried both soft and hardened the rear suspension spring but with no luck.
Any tips out there?
Does anyone know if there are "tip uo" rails on the 155" rails from 2008?
Thanks for reply =)
Rails are supposed to be tipped up on that sled. Limiters all the way out. Stronger from shock coil spring or more preload, mount top of shock in lower position, this gives it more height, rear torsion springs on soft.
  • Like
Reactions: KON
I noticed a few cracks in the chassis in front so I made a reinforcement bracket, when I made it I also dropped the mounting hole 20mm so it now is mounted like on the pro assault.
This was a good solution, the sled is easier to ride and is more playable then ever :)
