Need a sled, thinking of a new 14 pro
T
Tony skagen
Having a hard time deciding whether I should just buy a 2011 or 12 and save money or step up a little to a new 14 with warranty. Any input would be appreciated. Thanks
Find a 13 holdover with warranty.
Don't know how that is in CO, but no chance around here.
If you are close to Rexburg Motorsports in Rexburg, ID...give them a call as they have some great deals. A 2014 155 track last month was 10,300 out the door.
'11-'12 have welded lower a-arms. '13-'14 have glued on alum ends. The 11-12 do not have the thicker cylinder skirt like the 13-14. 13-14 has belt drive, for better or worse.
Maybe the warranties have improved but it sounds like more hassle than it is worth to me. I bought a '13, had the QD belt replaced under warranty but it has since expired. I turned up the oiler and plan to enjoy this like every other sled I have owned.
Nothing wrong with a 11-12 with a fix kit, long rod or decent warranty. It is debatable whether the 13-14 improvements (other than the engine) are really improvements at all.
It IS the best ride on the snow right now. I ride with Doo's and Cat's (M-series) and I am happy to be the only Poo rider. I think it is the most fun I have ever had on a sled. The '14 should be a great machine. I might go for an Assault if I were to do it over again. Steamboat had 2 '13 Assaults last month. Norwood had 2- '13 163 Pro's, either one could be had with more warranty than the '14s, 3 years vs 2.
For what I saved by not going brand new ($2000) I will put towards a drop in kit over the summer, some Timbersled lower arms and maybe a TKI belt drive to cure what ails the Pro.
I have a 14 for sale
I have my 14 that i snochecked for sale if your interested, has 85 miles on it currently. But i plan on riding it one more time this weekend. so would have around 150 miles. Its a 2014 163 800 in the midnight blue and has 2 year warranty.
Pm me if interested and for more details, we can maybe work out a deal on delivery
With the local NW snow conditions I would ride what you have for this year. Come April/Snowcheck time people start dumping sleds.
I bet you can find a 14 Pro 800 with tasteful extras(Bags, belt, cover, etc) with warranty and under 500 miles for $9-10K.
I have had a 12, 13, and 14 and the 14 seems to run the best but does need a few preventive things done.
Either way you'll love the Pro chassis.
Goodluck on your hunt!
Yea, I just did exactly as you said, found a guy who went on one trip and sold a 14 pretty reasonable. What type of preventative things do you recommend?
Thanks,
Dan
Thanks,
Dan
Dan,
Check oil usage and more then likely you'll need to turn up the oil pump.
Add 1 oz oil to 1 gallon of gas/premix it
Tunnel braces down by the footwell( FTX Motorsports, Van Amburg, Kmod, Kurts Polaris)
Footwellvents/You can make your own cheap or buy a set from Mike Taylor on Snowest
Look into a better rear bumper
Tether
Do some reading on here, ton's of info..
All 800's.
We had a 2011 155" and a 2011 163". The 2011 155" had a ETS go bad.
Other than that, zero problems.
We now have a 2013 155", and a 2014 155".
If you can swing it go with the 2014. But I believe the 2015 will be a game changer. So maybe you will hesitate. :face-icon-small-con
Well I am riding a 2012 Pro 163. Welded factory front "A" arms, Tunnel braces and a good after market rear bumper, RKT piston kit with no controler, clutch kit from Carl's cycle. And good old fashion chain drive instead of a belt. From all the drive belt and drive axle and front A arm problems you couldn't give me a 2013 or 14.
I wouldn't be scared of a '13 or '14 at all. There's been some that have had issues but well over the majority haven't had a problem. Problems seem to get blown out of proportion from what I've actually seen first hand.
Very true!
There were a small percentage of the 13s that had issues with the drive belt and axle at the first of the year, then there was a "fix" for that (axle), which worked well. The ones that had problems were VERY vocal about it, and posted about the issues so many times that it looked like a much bigger problem than it actually was. Then the other "brand loyalists" hopped on the bandwagon and the flaming continued :face-icon-small-dis
The 14 drive belt is much stronger and I haven't seen personally or even heard of a single issue on the 14 yet. I have a 14 and it is the strongest running stock sled i have ever ridden. Added the 3" track and could not be happier!!
In my opinion . .. find a 14. You wont be sorry =)
Cheers!
Have you thought about the standard RMK? welded A arms, chaincase, extra cooling, stronger rear bumper, cheaper!
